Harley Badlands Turn Signal Load Equalizer Type III - Namz LE-CB-D - Twin Cam Touring 2014+
by Namz
SKU 32-2146
$99.99
999 ENTRIES 🎟️
$99.99 - $99.99
$99.99
999 ENTRIES 🎟️
Badlands equalizer III works flawlessly with the new generation of modules and is compatible with virtually any of the custom turn signals available. This is the plug and play type. Equalizer is designed to specifically work on all Twins with OEM alarm system or self cancelling turn signal module. Solid state design works with Halogen or LED signals and elminates erratic blinking of signals. *NOTE: The ONLY time a load equlaizer is needed is when you install aftermarket turn signals on a 2011-UP FXST 2012-UP Dyna or ANY 2014-UP model and you have rapid flashing turn signal indicator lights. The bike will also throw a trouble code. Unlike earlier equalizer modules CAN/Bus bikes require (1) module for front and (1) module for the rear turn signals. Fits 2014+ Harley Touring models.
Namz #: LE-CB-D
2014-UP FLT
