Andrews Mainshaft 4th Gear 26 Tooth - Andrews 204260 - OEM 35065-65B
by Andrews
SKU 17-8231
$199.99
$199.99 - $199.99
$199.99
Andrews #: 204260 · OEM #: 35065-65B
Transmission mainshaft 4th gear is a stock ratio 26 tooth gear and measures 1.6290 inch outer diameter for loose rollers.
Order seal separately. *NOTE: Requires 88 loose rollers standard size.
  • Suggested to use with Standard Roller Bearings
1941-1977 FL
1971-1977 FX
