Aluminum Solid Pushrod Conversion Set - V-Twin 11-9535
SKU 11-9535
$69.99
$69.99 - $69.99
$69.99
Alloy pushrods feature a hardened steel tip at the ends. Pushrods are long enough to work with stroker flywheels and are sold in a set of 4.
Solid pushrod kit comes in a set of 4 and includes adapters. We put the adjuster into the lifter body to increase stablility of the pushrod at angles. A tapered split lock nut is used for the best way to lock the adjusting bolt into the lifter body. We use a 5/16 inch x 32 extra fine thread for easier and close adjustments. Pushrods are long enough to accomodate engines with stroker cylinders. Alloy pushrods have hardened steel tips.
1966-1984 FL
1979-1983 FLT
1982-1983 FXR
