Harley Touring Alternator Charging System Kit 54 Amp Chrome - Volt Tech 29900028A-CHR - OEM 29900028 - Twin Cam 2009-2016
Charging system kit includes the voltage regulator and mounting bracket featuring a chrome finish with the rotor and stator. This high output charging system is engineered to provide 30% more power than the stock system at idle. With 54 amps of output @ 4000 rpm accessories will operate at their peak performance - no more dimming lights reduced audio performance or under-performing heated gear. This is a recommended installation anytime a mutil-amp audio system is installed on the vehicle in order to achieve the full capability of your audio system. It is also recommended when installing heated seats heated gear and other higher draw powered accessories. Stock on select CVO Touring models the complete kit includes high performance rotor stator voltage regulator and all gaskets and hardware required for installation. *NOTE: Requires new oil cooler hose to be supplied by customer. Installation instructions (PDF). Fits 2009-2016 Harley Touring models.
Volt Tech #: 29900028A-CHR · OEM #: 29900028
- Produces 54 amp @ 4000 RPM's.
| 2014-2016 | FLHTKSE |
| 2009-2016 | FLHX |
| 2014-2016 | FLHXSE |
| 2011-2016 | FLT |
| 2014-2016 | FLTRUSE |
