Harley Accel SLM Ignition Module - Accel SLM05 - Twin Cam Touring 2008-2009
Accel SLM ignition module with throttle by wire system. This is a self learning module and plug and play utilizes for oxygen sensor. Module helps regain control of fuel injected bike and improves mileage while increasing power and torque reducing emission. Automatic recalibration-optimizing modifications gains expected from performance exhausts air cleaners and cam shafts. Easy direct plug in connections to factory throttle position crank shaft position and oxygen sensors. Self learning module seamlessly compensates for changing loads weather conditions and altitude while you ride. Smoother running engine eliminates the pop and bang associated with a mis-programmed ECU due to intake or exhaust modifications. The need to re flash the factory ECU has been eliminated. *NOTE: Not for sale in California. Fits 2008-2009 Harley Touring models.
Accel #: SLM05
| 2008-2009 | FLT |
