Harley Big Twin 95 Big Bore Twin Cam Cylinder and Piston Kit - V-Twin 11-2615 - Twin Cam 2000-2006
SKU 11-2615
$579.99
5799 ENTRIES 🎟️
$579.99 - $579.99
$579.99
5799 ENTRIES 🎟️
95 inch Big Bore bolt on cylinder kit will increase TC-88 engines to 95 inch. Kit includes black cylinders with 9.3:1 cast moly coated pistons that are pre fitted to cylinders with head gaskets. No crankcase machining required for installation. Does not require flywheel re-balancing. Twin Cam 3-7/8 inch Big Bore Cylinder Kit increases displacement of Twin Cam 88 (1450) to 95 (1550) cubic inches. These cylinders require no crankcase machining and are finished honed. Installation instructions (PDF). Fits 2000-2006 Harley Dyna, Softail, and Touring models.
  • Piston Size: 3.874
  • Cylinder Size: 3.8755
2000-2006 FLST
2000-2006 FLT
2000-2006 FXD
2000-2006 FXST
