85mm GPS Speedometer Kit - V-Twin 39-1148
85mm speedometer kit with 3 light dash cover includes stainless steel bezel and gauge with nylon body nut upper and lower adapter ring.
The nut allows gauge to be clamped to the dash panel using the 2 washers 1 on the outside and 1 on the inside. Kit is GPS signaled. Sensor must be externally mounted on the motorcycle to receive GPS satellite signal. Kit is to be installed in speedometer housings. Sensor pad and connector wire are suppled with kit. Gauge will require feed from a 12 volt battery to operate.
| 1956-1967 | FL |
