85mm GPS Speedometer Kit - V-Twin 39-1138
Speedometer kit includes 85mm 120 mph GPS speedometer. Three lights dash type speedometer features external sensor and adapter rings to fit 85mm into speedometer or tachometer into 120mm dash opening.
Kit is GPS signaled. Sensor must be externally mounted on the motorcycle to receive GPS satellite signal. Sensor pad and connector wire are suppled with kit. Gauge will require to feed from a 12 volt battery to operate. Kit is designed for FLH speedometers. Includes a 0-120 mph gauge with nylon body nut.
| 1956-1967 | FLH |
