85mm GPS Speedometer Kit - V-Twin 39-1137
Kit includes a 85mm GPS speedoemter with adapter ring to fit into 120mm dash openings.
Unit must be powered by 12 volt from electrical system and the externally mounted pad must be visible to the inchsky inch to received signal. The speedometer body features a 0-120 mph gauge with a nylon nut to clamp the upper and lower ring to dash panel.
| 2014-UP | FLHR |
