85mm GPS Speedometer Kit - V-Twin 39-1132
Kit includes an 85mm skull dash cover and a 120 mph GPS speedometer. Speedometer features external sensor and adapter rings to fit 85mm gauge into 120mm dash opening.
Kit is GPS signaled. Sensor must be externally mounted on the motorcycle to receive GPS satellite signal. Sensor pad and connector wire are suppled with kit. Gauge will require feed from a 12 volt battery to operate.
| 1936-1938 | EL |
| 1936-1938 | UL |
| 1936-1938 | WL |
