80 Shovelhead Rear Cylinder - V-Twin 11-0497 - OEM 16499-80A
SKU 11-0497
$229.99
$229.99 - $229.99
$229.99
OEM #: 16499-80A
Rear cylinder fits Shovelhead 1979-1985 80 inch models. Cylinders are for stock bore stock stroke and compression.
Cylinders are 88.86mm bore with + or -.005mm range of tolerance. Cylinder has a hole in the base. Pistons are not included. May require the use of a cylinder base nut set available separately. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003.
  • Bottom Flange I.D.: 3-5/8 inches
  • Suggested to use with #8601-8 Hi-Torque Cylinder Base Nut.
1978-1984 FL
1979-1983 FLT
1982-1983 FXR
