Harley Big Twin 80 Shovelhead Front Cylinder - V-Twin 11-0496 - OEM 16498-80A
SKU 11-0496
$229.99
2299 ENTRIES 🎟️
$229.99 - $229.99
$229.99
2299 ENTRIES 🎟️
Front cylinder fits Shovelhead 1979-1985 80 inch models. Cylinders are for stock bore stock stroke and compression. Sold each. Cylinders are 88.86mm bore with + or -.005mm range of tolerance and must be honed to standard size for proper fit. Pistons are not included. May require the use of a cylinder base nut set available separately. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003. Fits 1978-1984 Harley Big Twin, FX (Super Glide), FXR, Touring, and Shovelhead models.
OEM #: 16498-80A
  • Bore Size: 3-7/16 inches
  • Bottom Flange I.D.: 3-5/8 inches
  • Suggested to use with #8601-8 Hi-Torque Cylinder Base Nut.
1978-1984 FL
1979-1983 FLT
1978-1984 FX
1982-1983 FXR
