Harley Big Twin 80 Shovelhead Cylinder Piston Kit - V-Twin 11-2613
GME 80 inch Shovelhead cylinder and Wiseco piston kit are honed and prefitted with 9.5:1 compression forged pistons and rings. Set of two. They are ready to run and will require break-in. Please refer to proper shop manual for suggestions on break-in. For stock stroke only. For 1966-1978 Shovelheads. Will require the use of a cylinder base nut set available separately. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003. Installation instructions (PDF). Fits 1979-1984 Harley Big Twin, FX (Super Glide), FXR, Touring, and Shovelhead models.
- Suggested to use with #8601-8 Hi-Torque Cylinder Base Nut Set.
| 1979-1984 | FL |
| 1979-1983 | FLT |
| 1979-1984 | FX |
| 1982-1983 | FXR |
