80 Shovelhead Cylinder Piston Kit - V-Twin 11-2612
SKU 11-2612
$579.99
$579.99 - $579.99
$579.99
GME 80 inch Shovelhead cylinder and piston with genuine cast cylinders prefitted with 8:1 compression cast pistons and rings.
Set of two. For stock stroke only. They are ready to run and will require break-in. Please refer to proper shop manual for suggestions on break-in. For 1979-1985 Shovelheads. Order head base gasket separately. May require the use of a cylinder base nut set available separately. The wrist pin are of the piston may require minor honing for proper fitment of the wrist pin. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003.
  • Height of the Piston: 3-1/4 inches
  • Suggested to use with #8601-8 Hi-Torque Cylinder Base Nut Set.
1979-1984 FL
1979-1983 FLT
1979-1984 FX
1982-1983 FXR
