Harley Sportster 750 XR Rear Wheel Hub Chrome - V-Twin 45-0110 - Ironhead 1957-1984
XR rear wheel hub is chrome plated and includes 2 nuts. For 40 spoke hole rims. Features knock off threaded end for inchquick change inch rear sprockets. Includes 11/16 bearings to fit stock sportster axles that are pre 1979 models and one chrome lock nut. Accepts 11/16 inch axle shaft and 6-8 gauge spokes. Accepts 38 tooth splined rear sprocket 49 tooth splined engine sprocket and 51 tooth splined engine sprocket. *NOTE: Alloy splined adapter is for sprocket and disc mounting. Disc mounting is a very close fit and should be tapped with rubber mallet - being careful not to damage splines. Order additional set of XR 750 hub lock nut separately. Installation instructions (PDF). Fits 1957-1984 Harley Sportster models.
- Hub Length: 7-1/8 inches
- Center to Center: 1/2 inches
- Suggested to use with XR 750 Rear Hub Lock Nut Set Zinc.
- Suggested to use with 38 Tooth Splined Rear Sprocket
- Suggested to use with 49 Tooth Splined Rear Sprocket.
- Suggested to use with 51 Tooth Splined Rear Sprocket.
- Suggested to use with 750 XL Rear Sprocket Adapter.
- Suggested to use with 45 Tooth Splined Rear Sprocket.
| 1957-1984 | XL |
