74 Panhead Cylinder Kit - V-Twin 11-1688
SKU 11-1688
Original price $599.99 - Original price $599.99
$599.99
$599.99 - $599.99
$599.99
Panhead cylinder kit includes 74 inch cylinders fitted with standard cast pistons (8.5:1) and hastings standard FLH ring set.
*NOTE: Oil feeds rockers from inside cylinder - use correct base gaskets to seal drain oil passage.
  • Required to use with Replia 74inch Overhead Valve Piston Set Standard Size.
  • Required to use with 74inch FLH Piston Ring Set Standard.
1955-1962 FL
