Harley Big Twin 74 Overhead Valve Piston Set Standard Size - V-Twin 11-0322
SKU 11-0322
$159.99
1599 ENTRIES 🎟️
$159.99 - $159.99
$159.99
1599 ENTRIES 🎟️
Piston set 3-7/16 inch bore standard size has a compression ratio of 10:1. Set includes Hasting 3 piece rings 2 wrist pins and 4 circlips. **Note: Run engine at moderate speeds for at least 500 miles avoiding excessive running in lower gears in order to properly break-in new pistons and rings. Bore size is 3.4380 inch-3.4385 inch inner diameter. Installation instructions (PDF). Fits 1941-1977 Harley Knucklehead, Panhead, and Shovelhead models.
1941-1977 FL
1971-1977 FX
