74 Overhead Valve Piston Set Standard Size - V-Twin 11-0307
SKU 11-0307
$139.99
$139.99 - $139.99
$139.99
Piston set 3-7/16 inch bore standard size with compression ratio of 7.5:1. Set includes Hasting 3 piece rings 2 wrist pins and 4 circlips. Pistons have a steel expansion control strut cast
**Note: Run engine at moderate speeds for at least 500 miles avoiding excessive running in lower gears in order to properly break-in new pistons and rings. Bore size is 3.4380 inch-3.4385 inch inner diameter.
1941-1977 FL
1971-1977 FX
