74 Knucklehead Front Cylinder - V-Twin 11-0499 - OEM 16483-41
OEM #: 16483-41, 6-41B
Front cylinder fits Knucklehead 1941-1947 74 inch models. Cylinders are for stock bore stock stroke and compression.
Cylinders must be honed to standard size for proper fit. Sold each. Piston is not included. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003. Bore size is 3.4380 inch-3.4385 inch inner diameter.
- 74inch Knucklehead cylinders are without lip on top
| 1941-1947 | FL |
