74 Knucklehead Engine Assembly - V-Twin 10-1388
SKU 10-1388
Original price $9,959.99 - Original price $9,959.99
$9,959.99
99599 ENTRIES 🎟️
$9,959.99 - $9,959.99
$9,959.99
99599 ENTRIES 🎟️
Replica 74 inch long block Knucklehead with polished rocker boxes parkerized valve cover cups a Linkert bolt manifold the motor sprocket and an 18mm spark plug set. Fully assembled and tested for oil pressure.
Unit features replica crank cases overhead oiler provision from timing cover cast iron type flywheel assembled with stock rods and Torrington rollers with steel cages a valve train with tappet assembly featuring Sifton lightning cam pushrods chrome pushrod covers and a finned cam cover. Replica cast iron cylinders are fitted with 8.5:1 pistons and Hasting rings replica cast iron oil pump assembly with early style iron cover and a distributor mechanical advance with corresponding relay mount with distributor post guide slot. Includes brass M-74 Linkert carburetor. *NOTE: M-74 Linkert carburetor is pre-run installed and tested within our Motor Shop. Running! Manufacturer's Bill of Sale supplied.
1941-1947 EL
1941-1947 FL
