61 Overhead Valve 3-5/16" Piston Set.010 Oversize - V-Twin 11-2750
SKU 11-2750
$139.99
$139.99 - $139.99
$139.99
Piston set with 3-5/16 inch bore has a 7.0:1 compression ratio and is.010 oversize. Set includes a piston ring set 2 wrist pins and 4 circlips. Pistons have a steel expansion control strut cast.
**NOTE: Run engine at moderate speeds for at least 500 miles avoiding excessive running in lower gears in order to properly break-in new pistons and rings.
1936-1940 EL
