6 Volt Three Brush Solid State Relay - Volt Tech 77332 - OEM 74750-38
by Volt Tech
SKU 32-0056
$74.99
$74.99
$74.99
$74.99
$74.99
$74.99
Volt Tech #: 77332 · OEM #: 74750-38, 4785-38
Solid state relay is 6 volt three terminal style with a smooth chrome cover. It replaces original style mechanical relay.
Relay allows the use of charge indicating lamp on all 3-brush applicationsand is full function as a mechanical relay. The dash light will work.
- Relay end with single terminal is the armature connection. Battery connection is the lower terminal on the opposite end. Charge lamp is the upper terminal.
| 1938-1940 | EL |
| 1941-1957 | FL |
| 1938-1948 | UL |
| 1938-1952 | WL |
