6 Volt Ignition Coil 1.5 Ohms - Volt Tech 72373
Volt Tech #: 72373
Ignition coil is steel jacketed and includes nuts packing and wires. This 6 volt coil is for single point distributors. Coil features steel housing as original but brass plated for the vintage steam punk effect!
Coil has a 1948-1988 FL/FX style bracket which will mount onto studs on the frame. Order stud set separately. Replica coils feature the exact OEM construction but the difference is the wrap around casing. Also the top and bottom covers are formed from solid brass sheet! ***NOTE: Coils are factory tested before packaging. Full warranty thru the dealer where you purchased! Over 20 000 coils sold since 1990!
| 1948-1960 | FL |
