6 Volt Distributor and Coil Kit - V-Twin 32-1506
SKU 32-1506
$269.99
$269.99 - $269.99
$269.99
6 volt distributor and coil kit features a chrome automatic advance distributor a metal jacketed chrome coil and vintage wire set with boots
*NOTE: Drilling a hole in the plate helps to set advance when timing.
  • Suggested to use with Ignition Advance with Points Plate Assembly.
  • Suggested to use with Chrome Distributor Cover.
  • Points go on the front side for ease of adjusting. Both lobes should open & close points but the skinny lobe times the front cyclinder see service manual.
  • There is no mark on the cam. Must time at cylinder top dead center. Unit requires removal of front head for installation.
1948-1960 FL
