5 Stretch Gas Tank - V-Twin 38-0740
SKU 38-0740
$339.99
$339.99 - $339.99
$339.99
Gas tank with 5 inch stretch has a fuel capcity of 4.7 gallons.
Features 4 bolt mounting on the underside. The tank has a 5 inch stretch to the back of the tank for a more cleaner custom look. The stretch does not effect the mounts. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help to stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Front Width: 15 inches
  • Overall Length: 28-1/2 inches
  • Tunnel Length: 28-1/4 inches
  • Tunnel Width: 2-3/8 inches
  • Suggested to use with Kreem Gas Tank Combo Kit
