Harley J Model 5 JD 180° Ribbed Rear Fender Raw - V-Twin 50-1595
Raw rear fender, a direct replacement for a dented, rusted, or missing stock fender. Fits 1926-1929 Harley J Model models.
5 inch JD rear fender is blank raw steel without brackets or holes and can be used for restoration or customization.
Exact width as JD 1920's Harley's. *NOTE: One piece full 180° fender is long enough with enough material so that it may be cut or split to desired length for specific applications. Position cut drill mount holes as required.
- Width at Edges: 5 inches
- Depth: 13 inches
- Width End to End: 32 inches
- Thickness: 1.5mm
| 1926-1929 | JD |
