45 WL Chrome Side Fill Wrap Around Oil Tank - V-Twin 40-1006
SKU 40-1006
$239.99
2399 ENTRIES 🎟️
$239.99 - $239.99
$239.99
2399 ENTRIES 🎟️
Chrome WL side fill oil tank features 1/8 inch NPT inserts to accept rubber oil lines 2 coil mounting studs on the left side and the battery box to accept 12 volt mini batteries.
Tank also has a pocket built into the front of the tank to allow clearance of the stock battery box mount on the frame. Includes threaded filler cap and drain plug. Battery compartment measures: 3-3/4 inch deep x 4-7/8 wide x 4-1/4 high. *NOTE: Must order connector fittings separately. *NOTE: There is no need to remove the battery box tab!
  • Depth: 3-3/4 inches
  • Height: 4-1/4 inches
  • Width: 4-7/8 inches
1936-1963 G
1936-1952 W
