Harley Flathead 45 W/G Transmission Case - V-Twin 49-0172 - OEM 34702-41
SKU 49-0172
Original price $609.99 - Original price $609.99
$609.99
6099 ENTRIES 🎟️
$609.99 - $609.99
$609.99
6099 ENTRIES 🎟️
45 inch W/G transmission case. Case accepts: 3-speed 3-speed and reverse and 4-speed internals. *NOTE: 45 inch W/G transmission case requires components and hardware as listed for assembly separately. *NOTE: Bottom mount studs left countershaft transmission bushing both the inner and outer shifter bushings with the welch plug and the cam plunger bushing are installed. *NOTE: The main race required available separately has to be pressed in must be honed after installation. Installation instructions (PDF). Fits 1937-1963 Harley Flathead models.
OEM #: 34702-41, 2258-41
  • Required to use with Cam Bushing.005 Oversize. Required to use with Engine Case 1/2inch Welch Plug. Required to use with #9919-3 Transmission Bottom Stud Kit.
  • Required to use with Transmission Shifter Shaft Bushing Large. Required to use with Shifter Shaft Bushing Small.
  • Required to use with Left Countershaft Transmission Bushing. Required to use with #2655-1 Transmission Fill Plug.
  • Required to use with #9761-4 Kick Starter Trip Bolt and Nut Kit. Required to use with Transmission Case Cover. Required to use with Servi-Car Reverse Idler Shaft.
  • Required to use with Transmission Side Cover for on 4-speed Transmission Case. Required to use with #9836-10 Chrome Countersunk Washer Set 3/8inch.
  • Required to use with #9686-16 Sprocket Cover Stud Nut Kit Parkerized. Required to use with #9666-27 Transmission Top and Side Cover Screw Kit Parkerized.
  • Required to use with 2nd Gear Retaining Bracket.
1937-1963 G
1941-1952 W
1937-1939 WL
