45 Transmission Side Cover - V-Twin 49-0455
SKU 49-0455
$139.99
$139.99 - $139.99
$139.99
Side cover is made from drop forged cast steel to ensure top quality and is specially machined for a perfect fit with no visual differences onthe outside. Inside cover is made to fit 3 or 4-speed transmission gears.
The welch plug is installed. *NOTE: Order the reverse gear idler shaft separately. **NOTE: Requires holes to be enlarged and needs a stud set available separately. 4 speed transmission door *NOTE: Must be milled to accept 17T sprocket. **NOTE: The transmission mainshaft outer race and the transmission countershaft bushing is included.
  • Required to use with #17-1927 Sprocket Cover Mount Stud Set Parkerized.
1941-1952 WL
