45 Gas and Oil Tank Set - V-Twin 38-0860
Raw tank set accepts gas shut off rod kit. Set includes tank emblem mount strips only which can be used for restoration on 1947-1950 models.
Tank set is an accurate reproduction of the stock gas/oil tank combinationwith the fuel shut off rod feature. *NOTE: Tank set accepts 2 3 and cast lite dash and later 1947-1973 shifter gate for W2 and g model servi-cars. May require fuel rod and oil tank fittings alignment using V-Twin before applying paint. 45 tank set space as required to allow fitting dash base and cover use 5/16 inch inner diameter washer between tanks and frame. *NOTE: Must order emblem set separately.
- Gas Capacity: 3.5 Gallon
- Oil Capacity: 3.4 Quart
| 1947-1957 | G |
| 1947-1952 | W |
