45 Gas and Oil Tank Set Raw - V-Twin 38-0595
SKU 38-0595
$579.99
5799 ENTRIES 🎟️
$579.99 - $579.99
$579.99
5799 ENTRIES 🎟️
Raw tank set accepts cateye dash plate early 1936-1946 shifter gate and gas shut off rod kit. Set includes tank emblems and stainless steel trim strips which can be used for restoration on 1941-1946 models.
Tank set is an accurate reproduction of the stock gas/oil tank combinationwith the fuel shut off rod feature. May require fuel rod and oil tank fittings alignment using V-Twin before applying paint. Includes tank emblem and mount strips. *NOTE: Dash panel base may have to be modified for proper clearance. Some 45 tank installations with a cateye dash will require 1/8 inch spacers on the top of the tank tab bolt to allow dash base to fit properly. 45 tank set set space as required to allow fitting dash base and cover use 5/16 inch inner diameter washer between tanks and frame. *NOTE: Must order emblem set separately.
  • Gas Capacity: 3.4 Gallon
  • Oil Capacity: 3.5 Quart
1936-1946 G
1936-1946 W
1941-1952 WL
