4-Speed Prepped Transmission Case - V-Twin 43-0856
4-speed transmission case has countershaft bushings main drive gear race race retaining ring and oil deflector installed. Includes case mounting studs bearing retainer plate kicker stop plate and screws.
Studs should be installed with protrusion as noted: kicker studs 7/8 inch (22.2mm) mount studs 15/16 inch (23.8mm) for kick start applications. Right side bearing housing and kicker cover studs not included.
| 1936-1952 | EL |
| 1941-1964 | FL |
