4-Speed Big Twin Transmission Assembly - V-Twin 17-1954
SKU 17-1954
Original price $1,909.99 - Original price $1,909.99
$1,909.99
$1,909.99 - $1,909.99
$1,909.99
Transmission assembly features cast kick cover with a two piece offset kick starter arm as used on 1954-64 FL models.
Transmission top is ratchet type without neutral switch provision and includes original cast case with early style main drive gear 44 rollers and 2:1 ratio speedometer drive gear internal parts cast kick starter cover and components clutch rod throwout bearing ratchet top with natural finish with chrome dust cover mount studs seal and key. Transmission features a 3.00 ratio FL style gears. No Manufacturer's Statement of Origin is required Bill of Sale only. Transmission accepts 2:1 ratio speedometer. Includes a parkerized clutch release arm. *NOTE: All transmissions are fitted with a 22 tooth countershaft sprocket. Accurate look for 1941-1953 FL models. This is great for Bobbers Period Choppers or semi-restoration builds. Assembled in our NY motorshop using imported and domestic components.
1936-1952 EL
1941-1964 FL
