3-1/2 Wiseco Piston Ring.020" Oversize - Wiseco 3517X - Big Twin 0+
Wiseco #: 3517X
Replacement Wiseco piston ring kit are for a 3-1/2 inch bore and are.020 oversize. Rings are packed per piston.
Kit includes 1 top ring 1 2nd ring and a 3 piece oil control ring. Also can be used as a.020 over on 1340 80 inch 3-1/2 inch bore late 1984-1999 Evolution and 1978-Early 1984 Shovelhead engines. Rings are for use with Wiseco pistons.
- Replacement rings for piston set.
- Suggested to use with piston set
- Suggested to use with piston set.
| 0 | Replacement |
