Harley 23 Front ABS Wheel Bearing - V-Twin 44-0902
SKU 44-0902
649 ENTRIES 🎟️
649 ENTRIES 🎟️
Replacement wheel bearing for 25mm axle. For use on ABS and non ABS models. ABS models require one ABS bearing and one non ABS bearing. Designed for bikes with stock diameter or larger than stock diameter wheels. Bearings for larger than stock diameter wheels have a greater reinforced magnetic area that will not set off any engine codes after proper installation. Universal fit for most Harley applications.
  • Outer Diameter: 52mm
  • Thickness: 18mm
