21 X 2.15" Rolled Edge Chrome Wheel Rim - V-Twin 52-0701 - OEM 43662-80B
OEM #: 43662-80B
Chrome 21 inch X 2.15 inch drop center wheel rim with 40 spoke holes. This is a WM type with welded beaded construction.
This rim has a center valve stem hole. *NOTE: Full roll edge rim with weld on side. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Suggested to use spoke set.
- Rim width is measured by the distance between the rim flanges.
| 0 | All |
