2 Position Mini Key Ignition Switch - Volt Tech 78611 - Ironhead 1959-1972
Volt Tech #: 78611
Mini key switch includes 2 small terminals with the on-off position with screw terminals and small brass keys. Body diameter is 3/4 inch.
Small size 2 terminal with on-off operation makes this switch easy to install. Includes 2 early style brass Chicago style keys. *NOTE: Key removable in the inchoff inch position.
- Suggested to use with Mini Key Switch Bracket
| 1959-1972 | XL |
