1966 Fat Bob Gas Tank Set 5.0 Gallon - V-Twin 38-0543
Gas tank set with right side forward petcock fitting has a fuel capacity of 5.0 gallons. 3/8 inch NPT fitting was for 1966 specifically but will mount to all 1947-1984 FLH.
Petcock hole is 3/8 inch NPT to accept male petcock. Tank set is exact replica for 1966 FL. Accepts right and left bayonet cap set. Requires sanding and primer before painting. Petcock fitting should be masked or plugged for easy installation. It is suggested to pressure test tank and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Uses male style petcock on right side forward. Set is equipped with 1966-1972 emblem mount strips. Order emblems gas caps and petcock separately. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. *NOTE: 1966 specifically petcock is forward on the right side of tank 3/8 inch NPT.
- Top Length:
- Bottom Length:
- Rear Width:
- Front Width:
- Rear Height:
- Front Height:
- Front Tunnel Height:
- Rear Tunnel Height:
- Tunnel Length:
- Suggested to use with Stock Style Gas Cap Set Vented and Non-Vented.
- Suggested to use Kreem gas tank combo kit
- Suggested to use with Petcock Straight Outlet Natural Alloy.
| 1947-1984 | FL |
| 1979-1982 | FXS |
