1966 Fat Bob Gas Tank Set 3.5 Gallon - V-Twin 38-0852
SKU 38-0852
$249.99
$249.99 - $249.99
$249.99
Gas tank accepts 1975-up petcocks with nut and has a fuel capacity of 3.5 gallons. Features left side petcock outlet.
Tank accepts a 22mm left side petcock a stock dash and speedometer a bayonet type cap and has welded on 1966-1972 emblem mount strips. Petcock fitting should be masked or plugged during painting for easy installation of petcock. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. All tanks or tank sets will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. *NOTE: Must order cap set petcock and 1966-1972 emblem set separately.
  • Suggested to use with Kreem Gas Tank Combo Kit.
  • Suggested to use petcock for 90° right hand spigot.
  • Suggested to use petcock for 90° left hand spigot.
  • Suggested to use petcock if inward spigot is required.
  • Suggested to use with Petcock Straight Outle with Nut Alloy.
  • Suggested to use with Stock Style Gas Cap Set Vented and Non-Vented.
  • Suggested to use with OE Emblem Set with Black Lettering
1947-1984 FL
1979-1982 FXS
