1966 Fat Bob Gas Tank Kit 5.0 Gallon - V-Twin 38-0567
Bobbed gas tank kit includes 5 gallon gas tank gas cap set and emblem mounts welded in place.
For foot shift applications. Accepts 3/8 inch NPT petcock with male threads which are not included. Openings are located on the right side forward on tank. Tank set is exact replica for 1966 FL. Gas tank does not have holes on the left side to accept shift gate. 1966-1971 emblems with screws not installed. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Suggested to use with Weld-On Emblem Mount Strips.
- Suggested to use with Adhesive Mount Strips.
| 1948-1984 | FL |
