Harley Knucklehead 1936 Rear Brake Drum Raw - V-Twin 49-1344
Raw rear brake drum, a direct replacement for a cracked, scored, or out-of-round stock drum. Fits 1936 Harley Knucklehead models.
1936 raw rear brake drum features a 51 tooth sprocket that is riveted in place with a splash ring.
The 1936 only rear brake on 61 EL models utilizes front shoes springs cam and pivot studs from the same year! *NOTE: Drum is deep-drawn from steel plate (not cast).
| 1936 | EL |
