Harley Knucklehead 1936 Distributor Top Nickel Plated - V-Twin 32-1494
SKU 32-1494
$74.99
749 ENTRIES 🎟️
$74.99 - $74.99
$74.99
749 ENTRIES 🎟️
1936 distributor top has a notch for the wire exit and is nickel plated. *NOTE: Base is drilled and tapped for the early style points sets and also where the condenser fits on the under side. *NOTE: Bare top only without points. Fits 1937-1947 Harley Knucklehead models.
  • Suggested to use with Blue Streak Distributor Top Conversion.
  • Suggested to use with 1936 EL Distributor Base Nickel Plated.
1937-1940 EL
1941-1947 FL
