Harley 16 X 3.00" Rear Rim Drop Center - V-Twin 52-0230 - OEM 43085-97
Chrome rear 16 inch X 3 inch wheel rim with 40 spoke holes and drop center design. This rim has a small center valve stem hole to accept metal stems. Hole is 8.50mm. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. Universal fit for most Harley applications.
OEM #: 43085-97
- Rim width is measured by the distance between the rim flanges.
| 0 | All |
