Harley Panhead 12 Volt Distributor and Coil Kit - V-Twin 32-1504
by Volt Tech
SKU 32-1504
$339.99
$339.99
$339.99
3399 ENTRIES 🎟️
$339.99
$339.99
$339.99
3399 ENTRIES 🎟️
12 volt distributor and coil kit features a chrome automatic advance distributor a metal jacketed chrome coil and vintage wire set with boots *NOTE: Drilling a hole in the plate helps to set advance when timing. Installation instructions (PDF). Fits 1948-1960 Harley Panhead models.
- Suggested to use with Ignition Advance with Points Plate Assembly.
- Suggested to use with Chrome Distributor Cover.
- Points go on the front side for ease of adjusting. Both lobes should open & close points but the skinny lobe times the front cyclinder see service manual.
- There is no mark on the cam. Must time at cylinder top dead center. Unit requires removal of front head for installation.
| 1948-1960 | FL |
