103 Twin Cam Cylinder and Piston Kit - V-Twin 11-1754 - Twin Cam 2007-2017
This kit increases displacement of the TC-96 models to produce 103cc with stock flywheels.
These cylinders require no crankcase machining and are finished honed and include Wiseco pistons. Fits all 2007-11 Twin Cam 96 inch models with stock stroke flywheels. Can also be used on 2012-2017 Twin Cam 103 models as replacement cylinder set. *NOTE: This can also be used on 1999-2006 Twin Cam models but requires the use of 4-3/8 inch stroke flywheels.
- Suggested to use Top End Gasket Kit.
| 2007-2017 | FLST |
| 2007-2016 | FLT |
| 2007-2017 | FXD |
| 2007-2017 | FXST |
