1-Hole Crank Pin with Nuts - V-Twin 10-0685
by Eastern
519 ENTRIES 🎟️
519 ENTRIES 🎟️
New Old Stock inch 1-hole crank pin with nuts is original Army Surplus used on 45 inch models.
Has a wax and cosmoline oil coating which will needs to be carefully removed with a razor blade. You must align oil feed in flywheels with crank pin. OEM uses 2 different flywheels so hole location may differ. This crank pin includes 2 oil feed holes to fit both the early and later flywheels. The distance measured from the edge not including the threads is 2.516 inch.
1937-1973 G
1937-1952 W
