Upper Fairing Bracket Repair Kit - V-Twin 31-0344 - Shovelhead Touring 1979+
Upper fairing bracket repair kit repairs both left and right fairing brackets without removal of the upper brackets from your motorcycle. Kit includes left and right brackets and hardware.
Need to repair your broken fairing brackets but hate to remove the upper brackets from your bike? Check out this Upper Fairing Bracket Repair Kit from V-Twin MFG. The kit includes black brackets screws and lock nuts to repair bothleft and right sides. The drill bit is used to drill out the fairing bracket holes to accept the new bolts; which are included with the kit for your convenience. Installation is simple just remove the outer fairingand the screw from the inner fairing place the supplied fairing repair brackets screw from the inner fairing place the supplied fairing repair brackets in place and use the suppl ied drill bit to drill the three holes. Place screws and lock nuts in place. Return the outer fairing back in its position and you're finished! For use on 1979- up FLT models.
| 1979-UP | FLT |
