Factory Sample 16 X 3.00" Rear Rim Drop Center - V-Twin 52-2118 - OEM 43085-81
SKU 52-2118
$84.99
$84.99 - $84.99
$84.99
OEM #: 43085-81
Chrome rear 16 inch X 3 inch wheel rim with 40 spoke holes and drop center design.
This rim has a small side valve stem hole to acept metal stems. Factory sample are brand new pre-production parts but have imperfections in the finished surface. Check threaded and bearing holes for excess plating before installation. There are no physical defects such as cracks or holes there will be cosmetic imperfections only. Sample parts may show marks from installation test and fitment. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
