Replica 16 X 3.00" Black Drop Center Wheel Rim - V-Twin 52-0967 - OEM 43008-40
OEM #: 43008-40
New Old Stock inch replica black front 16 inch X 3.00 inch drop center steel wheel rim has conventional bead construction. Drilled for the 45 WL 1/2 front brake drum.
For use on front 45 solo model. Black finish for restoration or custome desires. *NOTE: New Old Stock from the 1990's surface finish is scuffed and blemished. inchNOS inch in this case is early aftermarket. *NOTE: Requires OE style spokes for assembly. *Note: UPS may consiner this part as packaged inchoversize inch for shipment as compared to the actual wei ht which will result in higher shipping costs.
- Bead Width: 3 inches
- Outside Width: 4 inches
- Required to use with Polished Stainless Steel 16inch Spoke Set.
| 1937-1952 | W |
| 1941-1952 | WL |
| 1940-1945 | WLA |
| 1942-1943 | WLC |
| 1937-1942 | WLD |
