18 X 2.5" Drop Center Chrome Wheel Rim - V-Twin 52-0707 - OEM 43005-70
OEM #: 43005-70
Chrome front or rear 18 inch X 2.5 inch wheel drop center rim with 40 spoke holes and an 11mm center stem valve hole.
This rim is the OE drop center style for 1970-1978 rear wheel on Sportsters with a drum brake. Rim has a center valve stem hole to be used with a rubber valve stem center valve inner tube. *NOTE: Full roll edge rim with weld on side.
- Rim width is measured by the distance between the rim flanges.
| 0 | All |
